A couple of things:
A cylinder problem in a 220 isn't the same as one in a 200.
Now...THERE'S some rocket scientifical comment, 'eh?
The point is...220s have OEM piston problems. That a 220 has a plating failure may well relate to the known PISTON disasters..not necessarily to the cylinder itself.
The 200 does not have the same or similar piston problems. A plating failure in a 200 came from something else.
KDXQ's pics are quite evidently of a simple plating failure. It started on the edge of a port..and it can be lifted with ballpoint
pen fer crine out loud! Somebody severely screwed this thing up.
Teee's is also at the edge of a port..but from all the aluminum stuck on the wall, you know it's an apples an oranges thing (the two cylinders). Besides being in 'opposite' areas on
both axis, even!
Muriatic acid will take that aluminum off. Obviously...the 'acid' part of that solution is something to take care with.
You're familiar with the alpha piston groupings of OEM pistons? Your cylinder and head will be marked with A,B,C,D,E,F,G.
...aw...never mind. Let's start with the question first.
A BTW...but an intake seizure is commonly a lubrication failure...and things related to that.
