I've searched through quite a few of the posts on this topic and I still have some questions. I've got a stock 02 KDX 220 (snorkel removed). Elevation is 500-1000ft. As far as the temp goes it's a wide range (Illinois) and I don't mind if I set it up for cooler weather (50-60 degrees)and then run a little rich when the temps climb. I'm currently running 32:1 semi-synthetic but I think I'll be changing to 40:1 with the same semi-synthetic (possibly full synthetic).
I haven't done the plug chop yet since neighbors are a little uptight about running it down the street at full throttle (and I'm close to the cop shop). I'm going to wait for the track to do that but I'd like to get in the ballpark before I head out.
I have the stock R1173L jet in the 3rd from top position, a 145 main and 42 pilot. From what I've seen and heard, most recommendations are to move the clip to the 2nd from top, run the stock main (145) and pilot (42) and then fine tune with the air screw.
Will that get me close? This is my first jetting experience and I'd hate for it to end badly (too lean).
