Questions on kx fork swap (completed)
ok so the forks i want to put on my 04 kdx 200 are off of a 04 kx250 what do i need to complete the swap? i would also like to use my brake caliper and wheel.
i need to press the stem out of the KX lower triple and put the KDX stem in the lower triple do i need somekind of spacer?
is there a list of stuff that i need to do in order to complete the swap?
Re: Questions on kx fork swap
Yes you will have to swap the steering stem. Yes, you will probably need a spacer/bushing for the upper triple. You will not be able to re-use your wheel without doing some sort of work to the KDX axle to make it fit the KX forks. Brake caliper ShOULD be fine. There is a ton of info in this section. Just take a look around and you should be able to find everything you need.
Made some Progress with the swap!
Got the stem swaped, caliper on, fender and only thing left to do is some how machine down the kx axle to fit the kdx hub or pick up a kx wheel.
Before the swap
After(almost done)
Before the swap
After(almost done)
Wow. Nice subtanks.
Instead of machining the KX axle you can machine spacers for the KDX axle and reuse your KDX wheel. Your brake line should be routed to the inside of the fork leg however.
yea i was thinking that the brake line would hit the tire some how because the guards push it closer so thats why i put it on the outside. now thinking about it, it would suck to have it catch on somthing like a branch as im ripping through the trails. For the machining the spacers for the kdx axle has me worried because it is a lot smaller then the kx one so i decided on just picking up a KX front wheel.bufftester wrote:Instead of machining the KX axle you can machine spacers for the KDX axle and reuse your KDX wheel. Your brake line should be routed to the inside of the fork leg however.
More Progress!
It is so close to being able to ride. just waiting on the kx wheel to ship and then just need to swap the tire over and its good to go! I just stuck the kdx axle through the hub to take a picture lol
Re: Questions on kx fork swap (completed)
Hello, its now been almost 10 years since i made this post and wanted to share a few pictures of my old KDX 200 i ended up selling.
Custom machined spacer for the steering stem, 2013 or 2014 KX450F front fender, Full FMF exhaust.
Nice job. It looks very good!
Thanks! Was a fun bike, regret selling it!
