Kx ignition fitment to a kdx250sr
Wingie
Country: New Zealand
Post by Wingie »
Imagehi guys i had a problem with my kdx250 sr where we couldn’t get spark and nothing we tryed could get any. So in the end i just gave up and fitted a full electrical system from a 95 kx250. Not sure if anyone is interested but this is how i did it
The sr stator mount is a center mount on a hub in the cases. The kx uses a normal mount on the outside off the staator plate and wound fit the kdx cases. So I then had to set the engine up in the milling machine at work and machine the center hub in the cases down to a height that I could then make up a adapter plate to bolt the kx stator on to. You have to be carful to get this height right with the flywheel cor clearance and to line the pick up trigger with the flywheel
I then set the engine at tdc and put a mark on the cases as this is needed to start lining up the timing. I then went to a friends house who has a 95 kx250 and and set his engine to tdc with a dail gauge and then matched all the timing marks from his bike onto mine. It was a lot off mucking around but seems to be work perfect at the moment
Wingie
Re: Kx ignition fitment to a kdx250sr
Post by Wingie »
More pics off the process
Wingie
Post by Wingie »
And some more
Has thanked: 10 times
Been thanked: 47 times
Winnie, you are definitely industrious and resourceful!
Wingie
Post by Wingie »
Thanks the whole bike has been a huge job that got out off control. This is it finished there is a lot off different things on it now to the original kdx
Has thanked: 66 times
Been thanked: 20 times
WOW! Congratulations on getting it all going. The bike looks great.
