Bottom end parts
Bottom end parts
Does anybody know where these extra peices go it fell out after taking out my gears I’m guessing the metal washer goes on the gear I put on here and I have a left over rubber ring and I already have one on the gears where does the other one go thank you
- image.jpg (2.5 MiB) Viewed 1521 times
- image.jpg (2.84 MiB) Viewed 1521 times
- image.jpg (3.09 MiB) Viewed 1521 times
Re: Bottom end parts
Does the second ruber ring go on this side bc theirs 2 and both fell off this thing
- image.jpg (2.37 MiB) Viewed 1506 times
Did you not take pictures as you were disassembling it?
Do you have a service manual?
Have you looked at the parts diagrams?
Yes I look in the manual before coming here it’s just one rubber ring and it fell off while dissembling and also I take pictures
Oh dang ok I see the rubber ring goes in the same spot the other one does thank you
you're welcome
those diagrams come in handy
- Has thanked: 3 times
- Been thanked: 2 times
Joey, the wide washer in your photo #3 is part number 92022 in the exploded diagram above. The diagram identifies the shaft that this wide washer goes onto as part number 13127.
