Kdx 1990 kx2000 fitment
1fletch
Country: Uk
Post by 1fletch »
Hi guys got the opportunity to purchase a kdx 200 e 1990 and have a 2000 kx125 , anyone done the engine in the perimeter frame , is it straight forward or am I better holding out for a h series kdx motor to match perimeter frame
Re: Kdx 1990 kx2000 fitment
Putting the E motor in the KX chassis is exactly the same as an H motor, they are nearly identical in size and mount points. The only issue with using an E motor is parts for the E motor in the future, they are getting harder to come by. The same is also true for the H motor but to a lesser degree. If both the donor bikes are complete and running I'd probably just ride the E as is. I will say that the hybrid is a fun bike, mine is a 2001 KX125 frame and 2003 KDX220 motor.
Ridea200
Country: Usa
Post by Ridea200 »
What type of riding (terrain/skill level), and condition of the bikes are a few other things to consider. I agree with bufftester though...If the kdx is in rideable shape, hit the trails, and see if you like it as is.
Any pics?
1fletch
Country: Uk
Post by 1fletch »
Not the best condition , I have a 1990 and 1996 so had the chance of this for the engine
1fletch
Country: Uk
Post by 1fletch »
Going to strip and rebuild the engine and put it in this 2000 kx frame
Hi. Look through some old posts. I think there is info in there about using the 1989 - 1994 engine in a 1999 - 2002 KX125 frame.
1fletch
Country: Uk
Post by 1fletch »
Hi guys engines out and getting rebuilt , I have been looking through the site regarding the pipe and silencer and believe I will have to use a 96 onwards kdx pipe which will require a small spacer or extension welding on and I believe a kx 250 tail pipe , can anyone confirm this before I start the purchase of these please
Ridea200
Country: Usa
Post by Ridea200 »
I'm not sure on the pipe year range part, but on mine (97 kx frame/00 200 engine) I used the down tubes off the kdx, among other reasons, but to not have to ad the pipe extension. Most just extend it though. One thing I was thinking was if I smash the pipe, I just want a new one to just bolt on...a lot depends on the exact motor position.
I suggest to keep reading, as you already have been. Even if its a different year chassis/motor combo. That's how I found out about the 250 silencer thing. Bolted to the chassis, and matched the pipes diameter. Some modification was needed between the pipe and silencer can though...
Sounds like your on the right track.
1fletch
Country: Uk
Post by 1fletch »
Thankyou and appreciate the feed back , seems a bit like get the engine in and have a play around with engine positions to get the exhaust set before welding engine mounts up
Ridea200
Country: Usa
Post by Ridea200 »
I think the main thing to consider is sprocket placement, then intake/exhaust. Motor mounts after everything is where you like it. On mine, the stock kx head stay held everything just right. Sprocket, and intake where perfect. Since I used the kdx down tubes, the motor mounts, loops, and pipe clearance where already there. Some fitment was needed though to the frame. The tubes had to be notched/bent over the pipe to center on the frame. Also, the frame, where it "splits" going towards the swingarm had to be notched/bent down to meet the kdx tubes. Sounds harder than it was...The hardest part was actually cutting into the kdx...😣
Just because I did it doesn't meen it's the way to go for you, but is something to consider.
1fletch
Country: Uk
Post by 1fletch »
Hi guys , I have managed to pick up a nice kdx 220 2000 engine for the kx /kdx hybrid build so will be going with that motor now , which means I can restore the 1990 which I enjoy doing , will keep you all updated on the builds
Congratulations. Keep at it. Take it slow and steady!
1fletch
Country: Uk
Post by 1fletch »
Cases came up nice on the 200 engine , just waiting on bottom end then that can all go back together
1fletch
Country: Uk
Post by 1fletch »
[album][/album]Image[/img]exhaust and pipe arrived just waiting on engine rebuild then can get it all lined up along with mounts welded
Looking good. Keep at it.
1fletch
Country: Uk
Post by 1fletch »
Got the engine in today, had to open up the cases to 17mm and take 5.5 mm and 7mm off the swing arm , going to have a day on it tomorrow to get everything lined up
Cool. Keep it going.
1fletch
Country: Uk
Post by 1fletch »
Well everything has started coming together, mocked up the kx airbox with kdx 220 air box rubber with aluminium plate mod to get the correct offset
Looks good to me!
1fletch: photo of engine cases & cylinder shows beautiful parts. Like diamonds and other precious stuff!
