KDX 220 stock carburetor
HSV-Dirtrider
Post by HSV-Dirtrider »
What is the stock carburetor for the KDX220? Is it the PWK35? Will the carb from a 200 fit or a PWK35?
I seem to remember these carbs being different.
1999 KDX200
2005 CRF450X
YZ250F 50th Anniversary Edition
Re: KDX 220 stock carburetor
PWK33 for the 220, 35 for the 200. You can use the PWK35 on the 220 no problem. You will lose a little low end, but make up for it in top end.
Yup, what he said.
pumpguy
Post by pumpguy »
Going the other way around works too. Obviously there will be some performance differences but it all depends on your needs and preferences.
I have a 33 on my 200 which started life as a 220. I haven't ridden it enough to comment further although the PO used it for several seasons with no complaints.
Thats the great part about these bikes, literally the only difference between the 2 is the cylinder and piston. You can swap every other part between a 200 and 220.
VTMTcowboy
Post by VTMTcowboy »
I have a 35 on my 220. It came off my 200 when I swapped to a Lectron. Works great. I think I can get the jetting a little more crisp off bottom, but other than that it was plug and play, which was great because it saved me a lot of money since I already had the 35. Good luck and enjoy!
jakeslouw
Country: South Africa
Post by jakeslouw »
Any chance a PWK38 will work on the 200H?
It can be made to work, though you would need to sort the jetting out. Currently running a 38 on my sons RMX250 and it runs well, but does eat a bit more fuel than the old 35 that was on there.
Post by John_S »
I can’t imagine a 36 or 38 fitting on the H series. It would be such a stretch to get the carb into the reed and air box boots and they’re taller.
