Hi,
I rebuild my top end. And now for the first houres the gasoline air mixture should be a bit more fat/richer… do i have to turn the air screw in or out?
Thanks. :)
Carburetor air screw richer mixture
- Country: Germany
Re: Carburetor air screw richer mixture
Are you wanting to run more oil than normal? If so, it is not needed.
Better to be rich than lean during break in. Just make sure it will idle and ride it. After 10 minutes of running/riding you can set your sir screw just like you normally would.
- Country: Germany
Ok, thanks. But in which direction do i have to turn the screw for rich?
Turning the screw in, or clockwise, is makes it richer.Laurenz_KDX200 wrote: 12:21 am Jul 01 2023 Ok, thanks. But in which direction do i have to turn the screw for rich?
- Country: Germany
Thanks a lot :) again
