Rubber heat shield for pipe on e models
JZ05220r
Is the Rubber heat shield really needed? Thank you and happy new year.
- Been thanked: 2 times
Re: Rubber heat shield for pipe on e models
Are you talking about the one that goes against the side panel to keep it from hitting? Mostly, yes it’s needed if you don’t want to melt your plastics.
JZ05220r
This is what I am talking about.Slick_Nick wrote: 11:45 pm Dec 31 2022 Are you talking about the one that goes against the side panel to keep it from hitting? Mostly, yes it’s needed if you don’t want to melt your plastics.
- 21E59EF9-45BF-480E-9FC5-2CE600888918.jpeg (162.06 KiB) Viewed 1094 times
- Molly's 70
Thats a heat damper. I would definitely keep it on.
JZ05220r
Ok gonna have to track one down. Thanks
