Sealing oem carb holder to reed block
JZ05220r
Post by JZ05220r »
I have plans to switch back to the stock reed cage as the Lectron will not work with the thicker v force reed block. I had an issue in the past with the carb holder not sealing fully to the reed block. I see that the built in o rings on the carb holder are what create the seal. I am wondering what the best solution is to be absolutely sure the reed block seals the first time around. Thanks
Re: Sealing oem carb holder to reed block
I always use the factory gasket.
JZ05220r
Post by JZ05220r »
Molly's 70 wrote: 06:28 am Nov 24 2022 I always use the factory gasket.
Hey, I’m talking about the area the carb holder and reed block that technically uses no gasket. Thanks and happy holidays
Been thanked: 2 times
JZ05220r wrote: 12:43 pm Nov 24 2022
Put a very thin coat of grease on the seal lip it will allow the boot to kinda slide around a bit and help everything line up.
JZ05220r
Post by JZ05220r »
Slick_Nick wrote: 10:11 am Nov 26 2022
Thank you I’ll give that a go.
kdxdazz
Country: thailand
Been thanked: 21 times
Post by kdxdazz »
I went through this before too, if the o rings are damaged or flattened there is no way of sealing it, you can't just cut a gasket as the seal also holds the white plastic insert into the reed block, I tried many different combinations but in the end I bought a new carb boot, if you are able do a leak down test and spray around the carb boot to check for no leaks, I also have a lectron
JZ05220r
Post by JZ05220r »
kdxdazz wrote: 07:57 pm Nov 29 2022 I went through this before too, if the o rings are damaged or flattened there is no way of sealing it, you can't just cut a gasket as the seal also holds the white plastic insert into the reed block, I tried many different combinations but in the end I bought a new carb boot, if you are able do a leak down test and spray around the carb boot to check for no leaks, I also have a lectron
Thanks. I had a thought. Maybe I can just run a small bead of rtv around the outer o ring. The one that’s closes to the edges or the carb boot.
Has thanked: 13 times
Been thanked: 22 times
JZ05220r wrote: 02:32 am Dec 03 2022
Do not use RTV in gasoline situations.
JZ05220r
Post by JZ05220r »
SS109 wrote: 12:49 pm Dec 03 2022
Ok i thought it was tolerant to gas.
kdxdazz
Country: thailand
Post by kdxdazz »
JZ05220r wrote: 06:11 pm Dec 04 2022
Tolerant to oil not gasoline, threebond 1104 and 1211 is tolerant to gasoline
JZ05220r
Post by JZ05220r »
kdxdazz wrote: 07:24 pm Dec 04 2022
So do you think it will be safe to use one of those on the carb holder to reeds surfaces? I was thinking i should only use it on the out side o ring that is built in to the carb holder.
kdxdazz
Country: thailand
Post by kdxdazz »
JZ05220r wrote: 02:21 pm Dec 16 2022
Yes, either one of those will work, 1104 fills gaps better 1211 is easier to remove, just remember to wipe everything down with thinners 10 times so it can bond
JZ05220r
Post by JZ05220r »
kdxdazz wrote: 03:42 am Dec 19 2022
Ok having a hard time finding 1104 in the US. Not sure what a good alternative would be here. Maybe Permatex moto seal or Hondabond 4.
