Turbine core silencer for E model discontinued?
JZ05220r
Post by JZ05220r »
I can’t find the turbine core anywhere, just the power core.....
JZ05220r
Re: Turbine core silencer for H model discontinued?
Post by JZ05220r »
JZ05220r wrote: 10:32 pm Nov 06 2022 I can’t find the turbine core anywhere, just the power core..... I’m looking at a universal turbine core but notice it slotted where it would connect the the expansion pipe. Not sure if this would slip over the fmf expansion pipe. Thanks
No, it's not discontinued. It's listed all over the place. RMATV, Motosport, CycleGear, Revzilla, even Amazon and more.
JZ05220r
Post by JZ05220r »
JZ05220r wrote: 10:39 pm Nov 06 2022 [quote=JZ05220r post_id=222877
JZ05220r
Post by JZ05220r »
SS109 wrote: 12:19 am Nov 07 2022 No, it's not discontinued. It's listed all over the place. RMATV, Motosport, CycleGear, Revzilla, even Amazon and more.
Oops I meant the e model lol
Yes, the E-series silencer appears to be discontinued. With that said, the best silencer for the E is the OEM silencer. It's durable, quiet, and easily repackable.
Re: Turbine core silencer for E model discontinued?
If you really want a Turbine Core for your E-model, it’s not terribly hard to modify an H model version to fit I would imagine. Some cutting and welding and BOOM!
sarrant
Post by sarrant »
I have an Answer SA Pro-2 for E-Series KDX available. Aluminum silencer with internal turbine core spark arrestor. Lines up and slips on perfectly with FMF pipe. Probably needs a cleanup/repack.
Answer S/A-Pro 2 would be awesome!
Post a FS ad with pics if you can. I would like to see one for an E model. I have a new one for KDX250. I have never used one, but it looks awesome. I have the first version on my 87.
JZ05220r
Post by JZ05220r »
sarrant wrote: 03:52 pm Nov 08 2022 I have an Answer SA Pro-2 for E-Series KDX available. Aluminum silencer with internal turbine core spark arrestor. Lines up and slips on perfectly with FMF pipe. Probably needs a cleanup/repack.
I’m interested. The silencer that came on my e model has answer etched in it ironically but it’s riveted so I can’t repack it and a bit beat up. If you could share a few pics I’d appreciate it
sarrant
Post by sarrant »
I will try to fish it out and get a pic, but are you sure the Answer silencer is riveted on both ends? Usually it is only one. Also, you can drill the rivet out and replace with a sheet metal screw upon reassembly.
JZ05220r
Post by JZ05220r »
sarrant wrote: 07:28 pm Nov 08 2022 I will try to fish it out and get a pic, but are you sure the Answer silencer is riveted on both ends? Usually it is only one. Also, you can drill the rivet out and replace with a sheet metal screw upon reassembly.
I will double check that tomorrow. Thanks for that tip with the sheet metal screw. It is definitely too beat up for my build and the look I’m going for.
JZ05220r
Post by JZ05220r »
Thank and I will double check. Thanks for the tip with the sheet metal screws. It is too beat up for the fresh look I am going for though.
sarrant
Post by sarrant »
Not sure that this is a restoration quality piece either, but it is a nice forest service approved arrestor that is exact fit for E-Series KDX and should clean up and repack nicely.
I recall it as being very quiet, especially for aftermarket.
JZ05220r
Post by JZ05220r »
sarrant wrote: 05:57 pm Nov 09 2022 Not sure that this is a restoration quality piece either, but it is a nice forest service approved arrestor that is exact fit for E-Series KDX and should clean up and repack nicely.
I recall it as being very quiet.
How much money would you like for that. I think maybe I could have it cleaned and polished. Thanks
JZ05220r
Post by JZ05220r »
Thanks for the pics. I can see that looking pretty nice if I cleaned it real good and painted it black. I’ll consider it. How much would you like for it? Thank you
That would clean up fairly easy.
sarrant
Post by sarrant »
JZ05220r wrote: 06:25 pm Nov 09 2022
How about 50 + shipping
Please take the wheeling and dealing to PM, email, or phone/text. If you need me to pass on contact info to each other please let me know and I'll be happy to do it. Thank you.
sarrant
Post by sarrant »
Email is my username at Gmail.
