Engine boggs bad on trails.
Ewbarger
Post by Ewbarger »
So, I have installed 158 main, left needle in 3rd position, and alone size smaller pilot. Still had the rich symptoms, so I replaced the mid body gasket on carb. Still running rich. Took out the Reed cage and found a cracked Reed. The cage is a Boyesen cage. Im ordering the right reeds and will go from there, but I'm pretty sure it will be running great with new reeds.
Re: Engine boggs bad on trails.
Oh wow!
That will definitely make it run poorly.
Report back.
Yeah, that might be a problem. :mrgreen:
OUCH!
