Kdx 220r fresh frp engine issues (ported cylinder rb head and 36mm carb)
Re: Kdx 220r fresh frp engine issues (ported cylinder rb head and 36mm carb)
It sounds like you need to raise the needle clip one position and try again. Mine is currently on the 2nd and if I put it on the 3rd the midrange would be noticeably flatter and would stutter. The stutter that you mentioned is the tell tale rich sign.
Yep, time to get your jetting dialed in. Follow the jetting guide in the Jets and Needles section here on the forum.
