Transmission Poll
sailorcolin
sailorcolin
Goofaroo
- KDXohio
Re: Transmission Poll
None of the above i use gold spectro 80 or 85 wt
sailorcolin
How do yall like the 80/85 wt oil? Hows it feel and how long have you been running it?
sailorcolin
I just switched to AFT an hour ago and I love it so far. Smoother shifts! However I did find out the owner before I stripped the drain plug hole :/ So soon enough I will be draining the oil again. So before I put in new oil I was wondering what you guys were running and what brands!
Goofaroo
It would never occur to me to use ATF or 10w40/10w30 "motor oil" so I can't say anything about that. I can however tell you that I have never used anything except oil designed for a 2 stroke transmission and I have never had any failures and the clutch action has never been a problem. My trannies have always been quiet and smooth shifting.How do yall like the 80/85 wt oil? Hows it feel and how long have you been running it?
I used nothing but Spectro for years and years but I can't find it around here anymore. That would be my first choice if it was available but I haven't had any problems with the Hondaline or Silkoline.None of the above i use gold spectro 80 or 85 wt
sailorcolin
- rbates9
Transmission Poll
Probably the best thing I had ever used was the Spectro 80? gear oil that I found in the back of my oil shelf from about 15 years ago. But I haven't been able to find it again. And after I changed the oil I tossed the bottle so I can't even remember what variation it was exactly.
But I have had good luck with ATF type F. It doesn't seem to last as long as the Spectro did but the other Spectro oils I have used didn't last any longer then the ATF. I have found that if they label it as any type of "Gear saver" or "Clutch saver" oil it isn't worth a sh!t and cost WAY too much for a one ride oil.
- adam728
Shell Rotella 15w-40 us a great low cost oil, and is JASO-MA approved for wet clutches.
ATF is a good choice as well, it is designed for a box full of gears and clutches.
Sent via morse code
Sent via morse code
- Trackdog
I'm finding this a little confusing.
Every manual I have calls for 10W-30 or 10W-40. Doesn't specify "engine oil" or
'transmission fluid"
I see trans. fluid comes in 10W-30, 10W-40 and 80W/85W. I see Type F trans. fluid on the shelf, but with no weight specified.
Hence the confusion.
My local Kawi dealer, who races the KDX, sold me Pro Honda HP Trans SAE 80W/85W for my 2005 KDX 200
2004 KX 125
1986 CR 125
1994 DR350
1998 VFR
2004 DUCATI S4R
2004 KX 125
1986 CR 125
1994 DR350
1998 VFR
2004 DUCATI S4R
- Has thanked: 66 times
- Been thanked: 20 times
Gear oil, 80 weight is equivalent to 10w-40, according to Bel-ray.
- Molly's 70
Amsoil oil 10w40 dirt bike oil for the trans.
