Shift shaft bottoming out on engine cover! Help!
Ecarta
Post by Ecarta »
Ok has anyone ever run into thus problem.
Trying to install my engine cover on this rebuild. But the shift shaft is bottoming out on the engine cover itself (see pic).
I triple checked the orientation of that washer/collar. And it's in the proper position and everything. But the ONLY way the engine cover will install is by removing it. But that also seems wrong.
Am I missing something here?????
Has thanked: 13 times
Been thanked: 21 times
Re: Shift shaft bottoming out on engine cover! Help!
Are you getting the collar seated in the shifting pawl fully?
Ecarta
Post by Ecarta »
SS109 wrote: 08:51 pm Apr 02 2022 Are you getting the collar seated in the shifting pawl fully?
At first I didn't understand what you meant....but after sleeping on it I put fresh eyes on it. And yes you are correct. Ya have to slide that plate back so the collar fits inside of it.
Thank you SS109!
Been thanked: 2 times
I see that you've already figured it out, but I had this problem once too, and it was also the collar that was out of place.
Awesome! Now go ride!
Has thanked: 66 times
Been thanked: 20 times
Cool. thanks for the info and pics, people. I bet that could happen to all of us.
KDXGarage wrote: 10:37 pm Apr 04 2022 I bet that could happen to all of us.
Yup. How do you think I knew to suggest making sure it was seated? :mrgreen:
penniar
Post by penniar »
I did the same thing last year. Took me about 10min to figure out. Important thing is you took the time to ask and didn't try to force it.
