KIPS rattle too load?
Laurenz_KDX200
Country: Germany
Post by Laurenz_KDX200 »
Hi,
i just bought a KDX200 from 2004. There is a pretty load noise besides the Enginesound.
Is this still the KIPS Rattle? Or is it something different?
Im worried to drive the bike with this sound🙈
Exspecially in the end of the video you can hear the strange noise clearly…
https://youtube.com/shorts/Tef70b4OEJE?feature=share
Would be verry pleased if you can cool me down with that noise 🙂
Re: KIPS rattle too load?
Definitely sounds like KIPS rattle to me but to the extreme. I would pull the pipe so you can see the operation of the sub-valves/flapper and operate the KIPS by hand to see if everything is moving correctly.
Laurenz_KDX200
Country: Germany
Thank you for your quick replay :) i will do so and tell here 👍🏼
Mr.Green
Post by Mr.Green »
Could also be clutch basket finger wear.Pull clutch lever in and see if noise changes.If clutch basket fingers are worn it will chatter.
Laurenz_KDX200
Country: Germany
The question is how to test the kips… the clutch doesnt make any difference…
Laurenz_KDX200
Country: Germany
Ah found this one ☝🏼
Laurenz_KDX200
Country: Germany
That will only tell you that the mechanism that drives the KIPS valves is working but doesn't show that the valves themselves are.
You'll have to pull the pipe, look up in the exhaust port, and move by hand that little plunger you see popping out in the video, and see if all the valves are actually moving.
Laurenz_KDX200
Country: Germany
Thanks for your quick reply. Have u seen the video behind the link of my last post? There you can see my KDX were i habe pulled the pipe and i am moving the kips 😁☝🏼
Laurenz_KDX200 wrote: 02:23 pm Apr 11 2022 Thanks for your quick reply. Have u seen the video behind the link of my last post? There you can see my KDX were i habe pulled the pipe and i am moving the kips 😁☝🏼
Good deal. didn't see it in the video but did you make sure the right subvalve was working also? If so, KIPS is good to go! However, checkout kdxazz's videos about the KIPS rattle: viewtopic.php?f=77&t=25522 and viewtopic.php?f=77&t=25525 While I do disagree with parts, he does cover some things that should be checked if you have excessive rattle from the KIPS and ways to fix it.
There is the copper gasket mentioned in a different thread.
Laurenz_KDX200
Country: Germany
Ok, the power valve is rappeling as hell 😁 you can see here in my video.
https://youtube.com/shorts/x2wd8o6fkBA?feature=share
Im trying the thing with the copper plate from the video above 👍🏼
Is there a special type of oil i should use when i reassembel the Kips? Should i use Locktite for these two screws?
penniar
Post by penniar »
Also check compression. My son's KDX was rattling pretty bad. I assumed it was the KIPs but when I tore the engine down, the KIPs wasn't even connected! The little actuator pawl ( the one that is secured with the nut with left hand threads) on the right side was not even contacting the KIPs main shaft. His top end was just that wore out.
Laurenz_KDX200
Country: Germany
Basicaly the kips are working in my case… But what made the noice in your case?
penniar
Post by penniar »
Worn top end. Piston was bouncing around in the cylinder. Combination of worn bore, worn piston, and worn rings. Glad I caught it before the piston shattered. Just got the cylinder back from replating yesterday. Plan on starting reassembly this weekend if everything checks out ok. My own KDX was getting a little noisy too. I rebuilt it last year including a cylinder replate and it is nice and quiet now.
Post by John_S »
Doing a new piston and rings in my 220 also took away what I thought was KIPS rattle.
[quote=penniar Just got the cylinder back from replating yesterday.
How long did it take them to replate your cylinder?
Laurenz_KDX200
Country: Germany
Ah f**k, i was hoping to leave the top end untouched, so i mustn‘t buy new top end gaskets… i have this compression measering tool in the picture below… how much psi should my KDX have to know that everything is fine inside the top end?
Is it possible to re-use the Gasket of the Cylinder Head?
Ps.: thank you all for your advices :)
Gamble and ride it or tear it down and know for sure. Have a serious talk with your wallet.
Laurenz_KDX200
Country: Germany
Thank you for the advice. I will go deep into my heart and my wallet and think about it 😁👍🏼
