Checking Stator & Fly Wheel
Boltonbubba
Country: America
Post by Boltonbubba »
I have a recently rebuilt 1987 KDX200 and am checking the generator before i drop it back in the frame. The 3 wire stator ohm check i get is 55 ohms black to white-red and 0.8 ohms black to yellow. The fly wheel has a few small chips on the edge of a couple of magnets. When i put a drill on the fly wheel and spin it clock wise and measure the AC volts between black (also grounded on motor) and the white-red wire I get a little over 2.0 V AC. This bike is a 6 VAC system is that only off the lighting wire or should I be measuring something close to that on the wires that go up to the coil and CDI? Any help is greatly appreciated.
Has thanked: 66 times
Been thanked: 20 times
Re: Checking Stator & Fly Wheel
Welcome to kdxrider.net.
Been thanked: 2 times
Don't bother with the drill spinny nonsense. Just measure the resistance of the stator windings and ensure that they fall within factory spec.
Boltonbubba
Country: America
So a few chips out of the magnets won’t matter much?
How big are the chips out of the magnets?
Small chips on the edge of the magnets are not a big deal, as long as they aren't big missing chunks. More important is to ensure there are no cracks or gaps in the inside face of the magnet that the coil sits next to.
The Black to White/Red is your exciter coil resistance, and seems a bit low to me, but that's compared to the later series bikes (I don't have the service manual for the C models). The Black to Yellow is your lighting coil resistance, which also seems a touch low, but not too bad.
The 6V is a reference to the lighting circuit, not the output of the exciter coil. The output voltage will change based on the RPM of the flywheel, and if you're getting voltage it's likely fine. The real test is whether you get spark or not.
For the chips its always a good idea to use a bit of epoxy to seal the chip, just use it sparingly and make sure it doesn't get anywhere it shouldn't.
Boltonbubba
Country: America
Merry Xmas everyone and thx for your reply’s. I’ve tried to attach a photo of the flywheel. No cracks, just chips, largest is maybe the size of half of a dime. The Clymer stator test specs are looking for 54.5 ohms and 0.5 ohms compared to the number I shared above.
Boltonbubba
Country: America
Here is another picture where i circled w/ a pen the areas of imperfection
Flywheel magnets
Flywheel magnets
Did you re-do the epoxy or someone before you?
Did this bike run in your possession before the rebuild?
Boltonbubba
Country: America
Someone must have done it before me, this came on a spare engine i picked up
Boltonbubba
Country: America
I’ve never had a bike running w/ this fly wheel
It appears as though whomever epoxied those magnets back on, marked the flywheel with a grinder or something. I have to say though, that even if one of those magnets was off by a couple of degrees, your ignition timing could be altered quite a bit. Might cause you some issues.
OK, so this is not a "it was running, and now it is not" situation.
Do you have another one to look at or is that the only one?
Boltonbubba
Country: America
I have two other flywheels that are in much worse condition. Are there any companies out there that recondition these?
Boltonbubba
Country: America
So put it all back together, connected coil and CDI…no spark. Changed the coil and CDI 2x to different ones I had…no spark. Tried it w/ the kill switch disconnected…no spark. I’m now thinking the fly wheel is the cause, don't really have any usable flywheels just another stator I could test. Any ideas on things to try?
Try a new flywheel.
I can't remember where I read it, but I recall someone using an H series rotor and stator on an 87 or 88 KDX. IIRC they had to drill the stator plate holes for the proper timing, but I don't remember anything else. Might be worth a deep dive into the interweb pool.
Boltonbubba
Country: America
Gents, after much trouble shooting I think I finally figured out the problem. When the previous flywheel owner refluxed the magnets he glued them on in the wrong order NNSS. The magnets are supposed to be NSNS. Also there are stops on the flywheel to help you position the magnets correctly. Soooo all you have to do is mix up some JB Weld (I use marine grade) coat the back of the magnet and the top/sides and slide it into position. Of course you need to clean off rust and old epoxy before regluing. But pretty easy. To detect what pole the magnet is you can buy a simple magnet pole detector (another NS magnet on a swivel…pivots to tell you the magnet pole) off Amazon for $6. Super easy to test…you’ll have you answer in less than a minute.
Boltonbubba
Country: America
One other thing I’ve learned is if you replace the stator, flywheel, coil and CDI with ones from and 1984-1985 it will also work.
WOW!! Put the magnets on wrong. Great catch, glad it took you only $6, truly amazing.
