The Weight
The Weight
So this happened...
the Steahly off road flywheel weight had a come apart and wrecked the cover. One of the set screws backed out. There is three of them. I checked when I installed it, considered putting on some threadlocker on 'em, but I didn't because they are peened in there...This shouldn't be possible, but it happened to me.
- IMG_20210928_141142939.jpg (2.68 MiB) Viewed 2418 times
- IMG_20210928_141131627.jpg (2.78 MiB) Viewed 2418 times
- IMG_20210928_141113249.jpg (2.94 MiB) Viewed 2418 times
- IMG_20210927_064828830.jpg (2.11 MiB) Viewed 2418 times
Re: The Weight
Murphy's law i guess, If it can happen, it will happen.
Any other damage beside the cover?
Will you keep the weight, or do without?
Re: The Weight
Bummer. Never trust anything if you don't have to! When I install a flywheel weight for someone that has the little set screws I always do so with some medium strength (blue) loctite on them. Just gives me peace of mind knowing they're not going to come back to me with a failure like yours. You can probably save that cover using some epoxy like JB Weld (not the putty type) or similar.
That said, I have always been baffled on why anyone would need/want a flywheel weight on any '89+ KDX. It already comes with a huge honking flywheel that is bigger than that comes on much larger and powerful bikes.
Re: The Weight
Doesn't seem to be any other damage. I'll probably put it back in with some loctite and try to peen 'em a little better. I found a cover on ebay, so that's on the way. True that the KDX comes with plenty of flywheel. This is probably not the most necessary of mods, but I kinda like it. It chugs along through the more technical stuff. Makes it that much harder to stall. Seems easier to find traction, and I stay off the clutch as much. So that probably keeps everything a little cooler.
- F Wheel 3.jpg (2.38 MiB) Viewed 2392 times
- F Wheel2.jpg (2.26 MiB) Viewed 2392 times
Re: The Weight
Who the hell needs a flywheel weight on the KDX?!
As a guy who had my actual flywheel come apart on me, (see here: viewtopic.php?p=215505#p215505 )the last thing I'd be doing is adding more weight to an already heavy flywheel.
Re: The Weight
Damn right! :-)
It might be the hot setup for where he rides. Hell, SS109 is still waiting for me to mail him a tree so he can plant it where he rides and have at least one there instead of catuseses.
Re: The Weight
I've got a few that are already broken in I could send him.KDXGarage wrote: 08:07 pm Sep 30 2021 Damn right! :-)
Re: The Weight
I'm not against mods, nut the KDX already has a heinously heavy flywheel. Can't see why you'd need to add more weight to it, but if you feel you need it, give'er.Whip! wrote: 10:30 am Sep 30 2021 Nobody needs one.
Who the hell would mod anything on any bike ever?
Re: The Weight
Yeah, it's only been forever!KDXGarage wrote: 08:07 pm Sep 30 2021]Hell, SS109 is still waiting for me to mail him a tree so he can plant it where he rides and have at least one there instead of catuseses.
Yeah, that was my kind of thinking as well. I guess if you ride nothing but super low speed technical stuff a FWW probably would be ideal.Slick_Nick wrote: 08:58 am Oct 01 2021I'm not against mods, nut the KDX already has a heinously heavy flywheel. Can't see why you'd need to add more weight to it, but if you feel you need it, give'er.
Re: The Weight
I know the KDX has more flywheel than most. That's one of the things I love about it. My step dad has been running a weight on his KDX for about 10 years now and never had a problem so I thought I'd try it out. I was glad I had it this day. next time I go up that mountain I'l probably drop a tooth on the countershaft too.
- image-023eab76-e6c0-4994-8b9f-4db47a3c4963.jpg (3.16 MiB) Viewed 2281 times
