RB Carb Clean Tips
Questions and Answers about the best carb and Head mods available for the KDX.
RB Carb Clean Tips
Post by Goat »
Are there any special tips to cleaning an RB-mod carb vs normal PWK?
Re: RB Carb Clean Tips
No, same as any other PWK carb. Don't soak it unless planning to replace the jet block gasket.
Post by Goat »
TY. I am hoping I find an obvious clogged jet or something. I have not cleaned it since installed. So expect something could have sneaked past the filter.
Post by Goat »
Jelly in the bowl. Fired back up 2nd kick.
Back on the path to recovery.
I bought one of those mini tanks to hang on bars. Cost way more than it should but sure is handy when the bike is in many pieces!
kdx633
Post by kdx633 »
I learned this from restoring a 1994 honda gold wing that had sat for 6 years.The goldwing carb is very complex with many tiny passages notorious for clogging up,they also have a felt shaft seal that when it goes bad or gets damaged it means a new and expensive replacement.Anyway on to facts.Using pure un-diluted ethylene glycol, heat in an old crock pot to about 140 turn off and drop the stripped carb into it for a couple hours(depending on how badly gummed up) remove, wash in soapy water,blow out and hit the body and passages with wd-40
works everytime and will not damage the jet block gasket guaranteed
Post by Goat »
Nice tip! Hope I don’t need it, but like the info. Thank you.
