Water coming out of head bolt
Jack Johnson
Post by Jack Johnson »
Back together after complete rebuild, I have antifreeze leaking from one of the head bolts. I'm guessing the new head gasket was bad somehow. Anybody else have this problem?
Practice, practice, practice.
Re: Water coming out of head bolt
Never had the problem. Which bolt is it leaking out of?
Jack Johnson
Left side right behind the water hose. You can see the water seep out of the threads.
Was the rebuild after normal wear or after a meltdown?
Did you remove the studs?
Jack Johnson
Meltdown I suppose, the bike needed a complete rebuild.
I did remove the studs.
TwistedRoot
Post by TwistedRoot »
Could it be that your cylinder head is slightly warped?
2002 KDX 200
2003 KDX 220
Put your head on a piece of glass & check for flatness with a .002 feeler gauge.
Jack Johnson
That is on the agenda for today.
Jack Johnson
Checked head with feeler gauge, doesn't seem warped. Used some 220 grit sandpaper on some glass just to be sure.
