Extra Spooge - theory
Re: Extra Spooge - theory
A quick check of sources of ethanol free gasoline in my area, Northeastern Illinois and Southeastern Wisconsin, show 87 octane just about non-existent. 91 octane is easily found. Is there an easy way to lower the octane of 91 and still have ethanol free gas?
Put 87 in it and run it hard in a mudhole our across a field. Listen to the lovely sounds of preignition and detonation. WHEEE at the damage.
Risk vs. reward, people.
Not that I’m aware of. 87 ethanol free is apparently hard to find in some areas. It’s a shame that you can only get ethanol free 91 because hardly anyone needs it.pumpguy wrote: 11:35 am Dec 23 2020 A quick check of sources of ethanol free gasoline in my area, Northeastern Illinois and Southeastern Wisconsin, show 87 octane just about non-existent. 91 octane is easily found. Is there an easy way to lower the octane of 91 and still have ethanol free gas?
I suppose I would use the 91 just to avoid the ethanol.
Sorry to rub it in but the gas station a few hundred yards from my house sells two types of fuel. Diesel and 87 octane non ethanol.
If that’s what you’re hearing you have other problems. Air leaks or timing is off.KDXGarage wrote: 02:39 pm Dec 23 2020 Put 87 in it and run it hard in a mudhole our across a field. Listen to the lovely sounds of preignition and detonation. WHEEE at the damage.
