I see the OEM are discontinued. Does any company make replacements? The pickings are slim on ebay.
Hoping maybe some other parts are compatible. Thanks.
Radiator Shrouds
Re: Radiator Shrouds
I think Maier used to make some, but I am not sure. DC Plastics might, but I don't know. Good luck on finding some used ones from eBay.
I don't know of any other shrouds that fit.
Yeah. I kind of figured they'd be hard to find. Same with the rear fender it would seem. :(
If you are OK with not having a light, the 1990 - 1991 KX125 / KX250 rear fender (UFO brand from Italy, for example, from Dennis Kirk and others) will fit with little modification.It fits pretty easily if you don't have the rear fender grab bars.
My 1991 KDX250 came with one, as best I remember.
Wow. Kudos for this link. THank you.
Please read up on vacuum molded / injecton molded to make sure you know what you are getting. Basically, it is not the shiny, perfect plastic like OEM / Acerbis / UFO / Polisport, etc.
- Country: Southwest United States
I ordered the DC plastic kit. They’re garbage. I used the rear fender and that was it. Yore better off trying to restore your plastics unless you desperately need a new set
