front brake caliper play
nelly001
Country: wales
Post by nelly001 »
hi while out riding sunday i noticed i had play in my front brake caliper as if 1 of the caliper bolts had come loose.after checking the bolts were tight i saw the caliper had movement on the bottom back and forth and after stripping the caliper bown and inspecting it i can find no wear on the pin or the hole in the caliper.only thing i can think of is the rubber boot which the pin slides in and out of is worn and causing play back and forth anyone else had this problem.are these rubbers a part that should be changed regularly as part of a service never come across this before
Re: front brake caliper play
Welcome to kdxrider.net.
Which year / model do you have?
nelly001
Country: wales
Post by nelly001 »
2000 kdx 220
knottyrope
Post by knottyrope »
ill have to look at my 220 when i do my pads
