I am now running a 40/150 jet setup. I dropped the needle (DEK) to clip #2 as well. It idles much better and revs pretty cleanly. It's lean though - plug indicates it and there were a few situations where a lean hesitation was noticeable so I'll have to figure out where to richen it up with the tuning manual now.
I'll address the filter in a bit - it didn't cause any issues on tonight ride and is more just of a means to an end. I got rid of the filters on the petcock side as they were destroyed anyways and filled with junk from the PO. My solution for having a filter was to use the inline for the time being.
So onto tonight's ride. The bike is a bike - it does dirtbike things. It was fun to be out after almost a month hiatus waiting on my Beta to be serviced with back-ordered Italian electrical parts... The suspension felt pretty damned good for a DIY front rebuild and rear basic rebuild (no revalve). Brakes were perfect - glad I replaced and rebuilt the front with a galfer line - one finger braking no problem. The elephant in the room however was the impression that the bike had a CVT for power transmission. It basically just would rev up after powerband and slowly collect more speed after that - it would audibly hit the peak rev then after a while it would physically keep pulling in speed/torque to match that change in engine sound. I started to have the impression that maybe the clutch is slipping? It just didn't seem right and not inline with what I've read about the KIPS system not working 100% (which is appeared to be during my tests both engine off and on).
So first, the glamour shots!
- kdx glamour shot.jpg (138.55 KiB) Viewed 10541 times
- KDX glamour 2.jpg (147.22 KiB) Viewed 10541 times
And now the clutch... I guess you could call the basket grooved? </S>
The clutch friction plates have matching grooves in them as well - just as deep.
- kdx clutch in engine.jpg (158.14 KiB) Viewed 10541 times
- kdx clutch basket grooves.jpg (139.93 KiB) Viewed 10541 times
And the springs were also compressed under spec...
- kdx clutch spring.jpg (155.77 KiB) Viewed 10541 times
So my question to the gurus on here - would this scenario cause the clutch to not engage as solid-ly as it should? The bike sounded like it was running great - reving clean and up pretty high... but the engine sound to rear wheel traction feeling that I know oh so well with my Beta 200RR 2T just was not there - not even in the slightest. It felt like I was on a snowmobile with a slipping belt...
The engine oil has a silver glimmer to it - but it's non-metallic (tested with a magnet wand, did not change motion of the fluid like you would expect like a 'ferrofluid'). I suspect this is aluminum being worn off from something?
I've never replaced a clutch on a dirt bike - and never fallen victim to a slipping clutch for that matter - call me lucky or just not one to own a bike long enough to deal with it.
