KDX250SR Build JDM 1192
Broady Auto
Country: Australia
Post by Broady Auto »
I am in the process of dismantling KDX250SR 1992 jAp import - Frame Number DX250E-009607
My questions
1./ Going by the research the Pistons are specific for these models - Are there any aftermarket ones available - and does SR mean that it is a JAp import or ar ether two types of SR
2/ What is the Standard bore size a quick measure I got 67.25 - just with digital vernier i will measure correctly later - I will need a NEw piston Rings and Top End gasket set
3/ Are these Nikasil or different type of plating
3/ What is involved in removing OIl Injection - is it just a natter of unbolting and making up a plate to suit - this mix oil in petrol
4/ If I remove injection - does anybody know if a std KX250 throttle cable of that era
5/ Anybody have LH side Radiator shrouds . Radiator Grill both sides and LD Side Plate available
6/ I have been supplied links to Jap arst Websites - Anybody have a Workshop Manual available for these to get clearances - torque reading etc
7/ Will a KDX Top end gasket kit suit this model
8/Will KX250 38mm Inlet boot suit for larger carby
9 The KIPS Valve dust boot , looks like this is no longer available 49006-1202 any other options
Re: KDX250SR Build JDM 1192
Hi.
https://en.impex-jp.com/catalogs/moto/k ... -1597.html
1992 KDX250-E2.png (179.04 KiB) Viewed 6475 times
From the Impex site, it looks like a standard piston from a dirt KDX250, 13001-1345. Wiseco used to make one.
Be sure to make sure the cylinder can use a stock sized piston or get the correct one for a sleeved cylinder if that is what you have.
https://www.partzilla.com/product/kawas ... 9b8092697c
The stock cylinder would have an Electrofusion coating, which is similar to Nikasil or plating / plated. It was not sleeved or iron / steel when new.
Broady Auto
Country: Australia
Thanks - to determine the piston size I will need the dimensions - any idea where the best place to get this information , not sure how to tell if it is a Electrofusion coating
Can you post pictures?
An inside micrometer or bore gauge would be the tools one would need to measure the ID of a cylinder.
Broady Auto
Country: Australia
Thanks, I know how to measure the bore and piston , I have the internal and external micrometer. I just need the specs to compare against , just quickly check the bore size is 67.25mm, the piston has a b stamped on it,
Broady Auto
Country: Australia
Pictures to follow
Dan 250sr
Country: Japanese version
Post by Dan 250sr »
Good luck finding piston
