Metal flakes in oil
Owyhee1
Metal flakes in oil
Post by Owyhee1 »
Does a few metal flakes in oil hurt anything?
Re: Metal flakes in oil- help
Most likely they are fine. Since you’ve already ridden it and it apparently seems fine, I’d go ride some more and not worry about it.
firsthere
Post by firsthere »
^ Same here, steel bearings and gears vs aluminum particles. I'd ride it also while monitoring the oil for shavings. Just for piece of mind.
Check it again soon. I would be worried that they are bronze flakes from bushings.
KDXGarage wrote: 10:37 am Jul 26 2020 Check it again soon. I would be worried that they are bronze flakes from bushings.
+1 The tranny has a bunch of bushed gears/forks that really like to be lubricated. IIWM I'd flush the bottom end real good, then go ride and check it again. Could have been initial wear from being underlubricated.
