Tubliss - install w/ new tire?
Re: Tubliss - install w/ new tire?
Post by Goat »
Pulled the trigger. Tubliss (rear only for now, since they are amazon sale) will be here Thu.
Yesterday I ran my tube / worn down Kenda Trackmaster rear at 9 lbs.
Nice difference in grip and forgiveness on the wet rocks & roots from my normal 11 psi and inspired me to go ahead and change tire tire to extra wide Kenda Equlibrium for even more grip and want to see what 6psi or 8 feels like.
Tubliss her I come.
GATOROC
Post by GATOROC »
Glad ya pulled the trigger! I'm really happy with my Tubliss setup. A few weeks ago I swapped my used Shinko Fatty and Tubliss over to my KX front wheel, and everything went fine.
2000 KDX 220
2024 Beta 300 RR Race Edition
Just take your time installing it the first time and follow the directions exactly. It is a little bit of a learning curve but once you got it down it's way easier, and better, than tubes.
Post by Goat »
Got it done tonight. Seems no leaks. Will recheck pressure and go for spin in the morn.
They could make the instructions a little more clear for me though.
I’d add: Place old tire well out of reach so you don’t accidentally try to remount it.
Post by Goat »
I couldn’t figure out where all the dirt came from on the bead. I had just pressure washed it.
New one looks better!
Post by Goat »
Oops. That was the “before” pic. This is the “after”
Looking good!
What size rear tire is that?
Post by Goat »
That is a 4.5-18. It looked a lot more at home on my XR650. We’ll see how she handles. KDXG likes it fine, so I expect good results. Headed for gnar today.
Man. That's wide! (assuming it is an actual 4.5", seems like they vary from manufacturer to manufacturer)
Post by Goat »
Looks like an honest 4-1/2”. Traction is pretty amazing.
Since I suck at real pivot turns, I do a lot of tight donuts. About launched myself into the ditch first time tried it with new tire. I ran 6/9 psi (front is still HD tube) pretty slick.
Post by Goat »
Pic isn’t really good, but caliper shows 4-1/2”.
