Newb carb question vm34
Michael93
- Country: Australia
Sorry may be a silly question but what's holes are for what etc I'm unsure
- received_881502758967079.jpeg (666.18 KiB) Viewed 6096 times
- received_1129040240779202.jpeg (727.5 KiB) Viewed 6096 times
1987 KDX200-D1 (AUS)
- Has thanked: 67 times
- Been thanked: 20 times
Re: Newb carb question vm34
WHAT THE HE**?!
Does it have an oil tank for the two-stroke oil??
top pic, upper left is a vent hose location, I suppose
MAN! That is different than the USA carb!
Michael93
Oh really I'm confused now haha, now no oil tank just mix in with the fuel,
lemme look around
maybe that second brass part is just a vent connection?
Michael93
1
- This is from kawasaki website but still no idea
- E1611.gif (98.87 KiB) Viewed 6091 times
Yeah, I think it is just a vent. One on each side, then one on the bowl (overflow).
Man. My eyes were tricking me. :-0
Michael93
Same here I dont remeber anymore than two hoses on my old one
I guess if it's running wrong when I start it I'll just putting my finger over holes lol
Michael93
This is mine and from here they looked to be blocked of unlike the new one they are open hmmm
- DSC_1348_50.JPG (967.15 KiB) Viewed 6089 times
OK, now that one looks normal to me.
Michael93
So if it doesn't run properly I'll lock then an see will let you know results ha
Michael93
Hang in there!
Michael93
I am sorta, so it's got a 6f39 needle so now I need to research and find excately what carb I have, maybe try my old jets so bit of trial and error coming up
Michael93
So my findings are you
Old carb new carb
H6-52. W8-71
V27-3. V27-3
Mj 340. Mj 320
Float bowl 1-f. Float bowl 2p
Needle 6fl52. Needle 6f39
So beside that all the dimension floats pilots seem to all be the same the 6f39 is about 4m longer and thicker at end
Old carb new carb
H6-52. W8-71
V27-3. V27-3
Mj 340. Mj 320
Michael93
Hey thought I'd ask before I do another post so after the carb I've setteld on putting the 320 jet in which is stock I think, and put the needle on lowest clip since it longer lol, so next I check my reeds/reed block and I noticed the plastic has been melting on one side, could bad reeds cause this and be half my problem with idle/and power
Thanks
- DSC_1366_50.JPG (1.29 MiB) Viewed 6055 times
Michael93
Edit sorry should mention the pedals they sit flushMichael93 wrote: 07:50 am Apr 06 2020Hey thought I'd ask before I do another post so after the carb I've setteld on putting the 320 jet in which is stock I think, and put the needle on lowest clip since it longer lol, so next I check my reeds/reed block and I noticed the plastic has been melting on one side, could bad reeds cause this and be half my problem with idle/and power
Thanks
I don't think the insert would be a problem.
Are you not running the stock carb?
Michael93
Same carb but like I said wrong needle,KDXGarage wrote: 11:57 am Apr 06 2020 I don't think the insert would be a problem.
One positive is I out the 320 jet in, put needle clip lowest and I can now get a good idle so a small win,
6FL52 is the stock OEM needle.
Michael93
Yep I know I bought a secondhand carby that was meant to have the needle, everything else was excately the same checked the needle and nope wrong needle :(
