After Market gear Shift
DeKay
Country: NZ
Post by DeKay »
Hi All My sons KDx200 year 2005 gear shift kept slipping took it off and see all the internal gear grooves on the shift are damaged and stripped plus it had previously been welded up. Any recommendation for aftermarket gear shifters thanks are place to get them from we are in New zealand. :supz:
Kdxfan4130
Country: Usa
Re: After Market gear Shift
Post by Kdxfan4130 »
Wonder if a shifter off another Kawi would work? I’ve got the hammerhead shifter on a 450x and it’s been crash tested a few times, I’m a believer as the Monkeys would sing
Restore rather than replace
Post by kdxsully »
First things first, is the shift shaft okay?? I like the hammerhead too.
The shifter pictured above is the same one Scotts sells just rebranded. I've got 7+ years of abuse on mine and holding up great.
DeKay
Country: NZ
Post by DeKay »
kdxsully wrote: 09:52 pm Mar 31 2020 First things first, is the shift shaft okay?? I like the hammerhead too.
Yes shaft ok with good groves its the OEM alloy gear lever that has damaged groves. thanks for the info
:prayer:
Alloy? Is stock not steel??
Post by kdxsully »
Probably a steel alloy. Everything’s an alloy to save a buck.
Some on eBay have real butter in the alloy. Some use Parkay.
