kdxquebec
Posts: 1255 Joined: 07:18 am Nov 24 2004
Post
by kdxquebec » 12:34 pm Feb 08 2006
Hi friends.
Again a will fit or not question
Are the 2001 220 stock carbs and 2005 220 stock carbs are identical?
Will the 2001 needle/slide/screw cap and cable will fit in a 2005 carb?
thanks a bunch (just to be sure before we buy)
phil
m0rie
Posts: 2220 Joined: 10:25 pm Nov 29 2004
Post
by m0rie » 01:50 pm Feb 08 2006
Phil - They should be the same.
kdxquebec
Post
by kdxquebec » 06:39 pm Feb 08 2006
Thanks Gs/m0rie...
Buykawasaki.com? what a great idea!!
They have the same assy part number so I suppose they are identical.
canyncarvr
Posts: 6943 Joined: 01:07 pm Nov 05 2004
Post
by canyncarvr » 11:37 am Feb 09 2006
If you're buying a used carb..at the very least know the jetting is going to be way off. Just assume it to be.
Be careful. Lots of things can be wrong that you won't know 'til after you get it. Unless you're after something in particular...try to determine (at least ask) that it has not been modified in any way. I've read of folks taking a dremel to their slide to modify the cut. Maybe that works sometimes..but I'd sure be leery of a carb modified in someones garage.
Other than that...I'm sure it will work out perfectly!!!
bike profile:
!clicky!
kdxquebec
Post
by kdxquebec » 07:27 am Feb 10 2006
I will confirm with the seller
Thanks
This is a long story...My friend need an other carburetor because his mother lost his carb.The carb was in a grocery plastic bag and she lost it.
Advice of the day
Never leave your carb to your mother.
Colorado Mike
Posts: 1921 Joined: 11:42 am Feb 25 2005
Post
by Colorado Mike » 09:26 am Feb 10 2006
Look in the laundry room, should be hanging on the door knob. That's where my mom put everything she didn't know what to do with.
Mike
'04 KDX220
