need some help pls not sure where locating pin go
- Kdxfan4130
- Country: Usa
Re: need some help pls not sure where locating pin go
Ooops, do you see 610 on the diagram? Is this the pin that was loose?
Are you able to take a picture of your bike? It would be helpful to see what you are seeing.
Thank you.
Thank you.
0ops_sorry wrote: 02:48 am Mar 07 2020...one more thing what kind sleeve do i buy also size of the piston send link pls ebay only..
rip i send my cylinder to some guy from ebay to get it sleeve rip my life sadface thanks for helpin out tho <3 i like to donateSS109 wrote: 04:45 pm Mar 08 20200ops_sorry wrote: 02:48 am Mar 07 2020...one more thing what kind sleeve do i buy also size of the piston send link pls ebay only..I can't believe no one has said anything yet! I would not recommend sleeving your cylinder! Send it off to have it replated. An improperly done sleeve will ruin your cylinder. With the cost of machining it for the sleeve, the cost of the sleeve itself, and the labor for doing it, you might as well have it repaired/plated properly by Millenium.
He could keep an eye out for a used cylinder on eBay and maybe sell the sleeved one on eBay.SS109 wrote: 04:45 pm Mar 08 20200ops_sorry wrote: 02:48 am Mar 07 2020...one more thing what kind sleeve do i buy also size of the piston send link pls ebay only..I can't believe no one has said anything yet! I would not recommend sleeving your cylinder! Send it off to have it replated. An improperly done sleeve will ruin your cylinder. With the cost of machining it for the sleeve, the cost of the sleeve itself, and the labor for doing it, you might as well have it repaired/plated properly by Millenium.
- Kdxfan4130
- Country: Usa
Can someone link the problems associated with going with a steel sleeve in the kdx cylinder? I’ve read slight difficulties when going that route
Restore rather than replace
The disadvantages of sleeves are: less durable than plating, higher friction, worse heat transfer characteristics, and porting can have poor match/transition to cylinder.Kdxfan4130 wrote: 04:36 pm Mar 09 2020 Can someone link the problems associated with going with a steel sleeve in the kdx cylinder? I’ve read slight difficulties when going that route
That said, If you've already bought the sleeve, just run it.
And it costs the same as a replate.
What they said!
sarrant wrote: 05:43 pm Mar 09 2020The disadvantages of sleeves are: less durable than plating, higher friction, worse heat transfer characteristics, and porting can have poor match/transition to cylinder.Kdxfan4130 wrote: 04:36 pm Mar 09 2020 Can someone link the problems associated with going with a steel sleeve in the kdx cylinder? I’ve read slight difficulties when going that route
- s-l1600 (1).jpg (219.59 KiB) Viewed 6884 times
got my sleeve todayKdxfan4130 wrote: 04:36 pm Mar 09 2020 Can someone link the problems associated with going with a steel sleeve in the kdx cylinder? I’ve read slight difficulties when going that route
- s-l1600 (1).jpg (219.59 KiB) Viewed 6883 times
All right! Take your time during reassembly. Don't forget about the left hand threads on the shaft and nut of the power valve system advancer rod.
thank you <3 for the infoKDXGarage wrote: 01:26 pm Mar 20 2020 All right! Take your time during reassembly. Don't forget about the left hand threads on the shaft and nut of the power valve system advancer rod.
Since you had it done, and if you don't mind saying, which company did you use for the sleeve and what was your total cost for it?
- Kdxfan4130
- Country: Usa
Looks like a nice job. Now you can bore it to the next oversize. Are there oversized piston kits available? Or do you need to find a piston off another brand I.e. Yamaha?
SERVICE was $120 https://www.ebay.com/usr/lynncampspeedshop-fb he did a good job bought a new piston and la sleeve total cost i say around 300SS109 wrote: 07:57 pm Mar 20 2020 Since you had it done, and if you don't mind saying, which company did you use for the sleeve and what was your total cost for it?
Thank you. This info will be helpful to others in the future if they are considering having their cylinder sleeved.0ops_sorry wrote: 01:15 pm Mar 21 2020SERVICE was $120 https://www.ebay.com/usr/lynncampspeedshop-fb he did a good job bought a new piston and la sleeve total cost i say around 300SS109 wrote: 07:57 pm Mar 20 2020 Since you had it done, and if you don't mind saying, which company did you use for the sleeve and what was your total cost for it?
done!!! <3 start in the 5th try maybe 7 loolSS109 wrote: 03:41 pm Mar 21 2020Thank you. This info will be helpful to others in the future if they are considering having their cylinder sleeved.0ops_sorry wrote: 01:15 pm Mar 21 2020SERVICE was $120 https://www.ebay.com/usr/lynncampspeedshop-fb he did a good job bought a new piston and la sleeve total cost i say around 300SS109 wrote: 07:57 pm Mar 20 2020 Since you had it done, and if you don't mind saying, which company did you use for the sleeve and what was your total cost for it?![]()
- 20200323_190740.jpg (1.18 MiB) Viewed 6595 times
