KDX220, new to me
rtbmrgl
Re: KDX220, new to me
Post by rtbmrgl »
javjacob wrote: 10:03 pm Mar 08 2020 Very nice!!! A good motorcycle suspension shop can rebuild that rear shock. For the gas tank check out plastex.net https://www.plastex.net/
I have used it to repair many plastic parts and it works great.
That looks like Q-Bond, which I think is sodium carbonate or sodium bi-carbonate and super glue. Works great.
Watched there video, looks like good stuff.
Mark
Roseville, Ca
'76 Bultaco 143 Frontera
'06 GL1800
'01 KDX200
'97 KDX220r
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
rtbmrgl
Post by rtbmrgl »
The 220 is done, runs good other than about 1/4 throttle,
Idles fine and just off idle. 4 strokes at about 1/4, 1/3 throttle on runs great.
Only mods are Boyesen reeds, FMF desert pipe and snorkel removes.
Stock jetting,
Main-145
Pilot-42
Needle- R1173l
Air screw- 1.5 out
Any suggestions
I tried raising and lowering the needle 1-up and 1-down no difference
I do have a 35mm from a 200 to try.
IMG_4491 - Copy.JPG (266.86 KiB) Viewed 5463 times
Mark
Roseville, Ca
'06 GL1800
'01 KDX200
'97 KDX220r
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
javjacob
Post by javjacob »
Looks awesome!
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
rtbmrgl
Post by rtbmrgl »
javjacob wrote: 08:42 pm Mar 12 2020 Looks awesome!
Thanks, just need to get to jetting a little better.
Mark
Roseville, Ca
'06 GL1800
'01 KDX200
'97 KDX220r
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Kdxfan4130
Country: Usa
Post by Kdxfan4130 »
Plug looking rich you might try one smaller pilot jet. Especially if your needle clip is in the upper 2 clip settings. You didn’t say where the clip is currently, not sure what four stroking is. I’ve found blubbery sluggish is rich, to lean it runs too good zingy quick revving puts a hole in the top of the piston.
Nice kdx holy moly!
Restore rather than replace
rtbmrgl
Post by rtbmrgl »
The was in the middle position, I raised and lowered it one clip, didn’t seem to make a difference. 4-stroking, running rich. I’ll try smaller pilot jet.
Mark
Roseville, Ca
'06 GL1800
'01 KDX200
'97 KDX220r
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Keep a thicker needle in mind.
It looks great!
rtbmrgl
Post by rtbmrgl »
KDXGarage wrote: 12:29 am Mar 13 2020 Keep a thicker needle in mind.
It looks great!
Thanks, I tried a 1174 needle, and didn't seem to make a difference either.
My jetting will be put on the back burner, my March trip was canceled.
In lieu of what I have been reading about cracks in pistons. I'm taking the cylinder off and replacing the piston.
Mark
Roseville, Ca
'06 GL1800
'01 KDX200
'97 KDX220r
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Before you start changing jets, make sure the air screw is set correctly for what you have. Just a suggestion.
rtbmrgl
Post by rtbmrgl »
Well I removed the cylinder, and found the plating is coming off between the exhaust port and the top of the cylinder. So I guess sending it to be re-plated is the answer. Where is a good place for re=plating.
IMG_4506 - Copy.JPG (191.99 KiB) Viewed 5443 times
Mark
Roseville, Ca
'06 GL1800
'01 KDX200
'97 KDX220r
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Millenium or PowerSeal
For example:
viewtopic.php?f=77&t=24041#p206710
javjacob
Post by javjacob »
Millennium is the best.
rtbmrgl
Post by rtbmrgl »
Thanks, I called Millenium,
Mark
Roseville, Ca
'06 GL1800
'01 KDX200
'97 KDX220r
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Twinsig
Country: USA Mid Bama
Post by Twinsig »
If you want to save a few bucks on a new piston send me a PM.
2003 220R
rtbmrgl
Post by rtbmrgl »
Twinsig wrote: 03:43 pm Mar 15 2020 If you want to save a few bucks on a new piston send me a PM.
Thanks, I actually bought a Wiseco, I sent it off to Millennium with the cylinder.
I didn’t see a PM link on you profile.
Thanks anyway.
Mark
Mark
Roseville, Ca
'06 GL1800
'01 KDX200
'97 KDX220r
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
VTMTcowboy
Post by VTMTcowboy »
rtbmrgl wrote: 05:47 pm Mar 12 2020 The 220 is done, runs good other than about 1/4 throttle,
Stock jetting,
Main-145
Pilot-42
Needle- R1173l
Air screw- 1.5 out
Any suggestions
Beautiful bike and outstanding find! I am out in Napa if you ever want to ride. I ride Foresthill mostly but I am open to wherever. Take care.
rtbmrgl
Post by rtbmrgl »
Got my shock back today, $110 later, new seal, oil, gassed up and ready to go.
Mark
Roseville, Ca
'06 GL1800
'01 KDX200
'97 KDX220r
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
