need some help pls not sure where locating pin go
0ops_sorry
Post by 0ops_sorry »
hi i did a oil change and saw a pin called locaitn pin not sure where that little pin go anybody can help me ??
Re: need some help pls not sure where locating pin go
Did you remove the side cover to change your oil?
The locating pins are located in several locations in the outer case and inner clutch covers. Only way to know where it goes is to take it back apart.
If the pin came out when you opened the oil drain plug on the bottom of the motor then you have bigger problems, and it is likely not a locating pin but the lower portion of your KIPS actuator.
bufftester wrote: 11:50 pm Mar 04 2020 Did you remove the side cover to change your oil?
:supz:
0ops_sorry
0ops_sorry
i found it thanks god here a picture and the pin i was takin about
Screenshot (168).png (1.06 MiB) Viewed 6886 times
Post by kdxsully »
Ohhhhhhh the key for the primary gear. And the pin.
How did you lose the key on an oil change? That's a pretty aggressive maintenance plan lol
0ops_sorry
bufftester wrote: 06:07 pm Mar 06 2020 How did you lose the key on an oil change? That's a pretty aggressive maintenance plan lol
i traded it for yamaha blaster lmao but what i dont get is my cylinder is trash but hold 150 psi also bought me a sleeve
0ops_sorry
kdxsully wrote: 05:20 pm Mar 06 2020 Ohhhhhhh the key for the primary gear. And the pin.
yes very happpy to find that tiny pin
Kdxfan4130
Country: Usa
Post by Kdxfan4130 »
Flywheel woodruff key
#610?
Restore rather than replace
0ops_sorry
Kdxfan4130 wrote: 08:19 pm Mar 06 2020 Flywheel woodruff key
#610?
omg noooo sadface no way im gonna open up my cases too much work for a pin
Feel this is a troll at this point, not one question answered. No one is that stupid accidentally.
0ops_sorry
bufftester wrote: 11:41 pm Mar 06 2020 Feel this is a troll at this point, not one question answered. No one is that stupid accidentally.
sorry im new at this im not a troll.. :cry:
He is saying he found the water pump pin. He didn't have the woodruff key missing.
Is it 4 mm wide and 8 mm long?
Can you take a picture of what you are looking at so we can see too? Thanks.
0ops_sorry
KDXGarage wrote: 01:41 am Mar 07 2020 Is it 4 mm wide and 8 mm long?
sure ill do.. one more thing what kind sleeve do i buy also size of the piston send link pls ebay only..
0ops_sorry
this is the pin im talking about i change my oil 4days ago and saw that little pin
Are you certain it is not a portion of the pin on the KIPS advancer lever? They usually break off when improper technique is used on removing the lever and left hand threaded nut.
0ops_sorry
KDXGarage wrote: 03:00 am Mar 07 2020 Are you certain it is not a portion of the pin on the KIPS advancer lever? They usually break off when improper technique is used on removing the lever and left hand threaded nut.
are you talkin about this one ?? it also broke so i order one yesterday
I am not seeing a picture.
EDIT: I am now. Yes, that one.
