First Time Plug Chop
- Goat
Can I tell anything from this exercise, given the mistakes I made?
Picked too short of road so only got thru 4th.
Did not get it shut down as fast as I think I was suppose to when i pulled the clutch in.
It is harder to find a deserted 1/4 mile strip than I expected.
- 02964B7D-D21D-4774-8F93-0184A6D9959D.jpeg (592.98 KiB) Viewed 4448 times
- 48CE27AB-A073-4442-89B1-73715DE52BD4.jpeg (835.41 KiB) Viewed 4448 times
Re: First Time Plug Chop
This was a new plug?
- Goat
Yes. This was new plug.
I am thinking it really doesn’t tell me what I need to know. Or I could make false judgement.
The bike does not “seem” lean by the seat of pants + based on the fair bit of smoke & spooge it produces.
I think I should probably find a better road and try again.
The band needs to be down toward the bottom.
I think the wide portion is the "did not get it shut down soon enough" portion.
viewtopic.php?t=12283
- Goat
and this is a KDX50, correct? KDX80?? :-)
- Goat
Hah! I do need one of those, though. My 50 is a mini trail and it just collects dust since the KLX140 came home.
- C8E54B4C-E95E-4EBA-BA8E-5D9461863171.jpeg (645.92 KiB) Viewed 4406 times
You don’t need a longer road. I’ve done this multiple times and it works great.
Fully warmed up engine
New plug 1st through 4th wide open pull in the clutch but don’t kill the engine. Turn around and do 1st through 4th again this time pulling in the clutch and killing the engine. That few seconds of idling while turning around is not going to ruin your reading. You could even do 3 or 4 1st through 4th runs. Only doing wide open and clutch in idling to turn around. Main thing is no half throttle or compression braking. Cut the plug like you did and you’ll have a good main jet color band showing what you need to do next with jetting. Wet cardboard color 2mm band down low on the plug would be perfect.
Check out this thread. These were some plug chops I did. Never got into 5th or 6h gear. It was 2 different engines but shows the different looks of the plug with 3 different main jet sizes.
viewtopic.php?f=86&t=23507
Excellent post.John_S wrote: 10:49 am Feb 22 2020 Check out this thread. These were some plug chops I did. Never got into 5th or 6h gear. It was 2 different engines but shows the different looks of the plug with 3 different main jet sizes.
- Been thanked: 10 times
I didn't say it before but I will now. That is one of the most informative threads I've ever read on a forum. Kudos!John_S wrote: 10:49 am Feb 22 2020 Check out this thread. These were some plug chops I did. Never got into 5th or 6h gear. It was 2 different engines but shows the different looks of the plug with 3 different main jet sizes.
- Goat
That is the post that got me itching to do some chopping. It sis a great one.
I really appreciate the info and possibility to run just to 4th gear.
I still have to find new road, since I met the neighbors there on my first try. And they asked if I could find a different route. Thanks very much.
