Hey kdx250 1991 SR model kx250
Stevetooms
Country: United Kingdom
Post by Stevetooms »
Does anyone know if a kx250 carb and piston kit will work and fit into my kdx250 1991 SR model thanks
Re: Hey kdx250 1991 SR model kx250
Post by kdxsully »
No idea. Are the part numbers the same? Check partzilla for the part numbers of each respective bike. You might need the carb boots as well
Please do not post the same or very similarly worded question in multiple subforums.
Sorry that you have not received more help for your unique model.
Stevetooms
Hey thanks for your help
Dan 250sr
Country: Japanese version
Post by Dan 250sr »
Change inlet manifold to 38 and a kx carb will work.. kx 250/ 500 inlet manifold are 38 ... your con rod small end is a different size to a kx . One is 18 mm bearing and the other is a 19 mm bearing... also kx wrist pin is in a different place to kdx piston.. you can fit a kx con rod and a earlier kx barrel 89 /90 . 70 mm stroke/ 91 92 use 72 mm stoke so won't work unless you machine top of barrel. I had my head machined to lower squish gap .
THANK YOU, DAN!!
Dan 250sr
Post by Dan 250sr »
No worries hope it helps 👍
