Oil leak between stock pipe and silencer
Why do I have a oil leak between stock pipe and stock silencer put new rubber at the connection
Re: Oil leak between stock pipe and silencer
Running rich...spooge. Proper jetting can eliminate most all of it.
Welcome to kdxrider.
Have you seen in the service manual about blowing out the extra oil? (cleaning)
Also, if the jetting is off, there will be a good bit of unburned oil in there. Clean it all out and get the jetting / mechanical operation correct to help it out.
