Hi there,
I am in the process of replacing my basket & clutch plates on my 95 200. I was wondering if there is a post/video here that shows the step by step removal procedure? I have Cyclepedia, but it's seems a little robotic for my liking. Appreciate the feedback.
95 kdx 200 clutch basket/plates removal
Re: 95 kdx 200 clutch basket/plates removal
No video that I know of. It's pretty straightforward though. Just follow everything step by step. It's a good idea to use a flywheel holder on the ignition side or improvise a way to do it without damaging the clutch basket. Also, an impact wrench really helps.
Pretty much any 2T video on clutch replacement will give you the general idea, along with the specifics from Cyclepedia.
Welcome to kdxrider.
I made a clutch holding tool out of an old steel clutch plate and a piece of scrap steel, bolting then together with some nuts, using nuts in between to space it. Works good if you don’t need to do the job often.
