Clutch cable bracket broken any good repair ideas
Thekid1995
Post by Thekid1995 »
I just bought a 1995 kdx it hasn't had a easy life from the looks but it was the right price and I'm always challenging myself. Anyway as I was saying the case clutch bracket is broken off at the top. Anyone else have this. If so did you fix it and how did you do it. Thanks for letting me join your group
Re: Clutch cable bracket broken any good repair ideas
Which part is broken? Where the cable stop is? If so you may be able to have somone weld a new bracket on, would take a bit of fabricating. Easiest answer is find a replacement case, theres one on Ebay for 99, another for 179. New will run around 250 if you can find one.
Has thanked: 71 times
Been thanked: 20 times
Welcome to kdxrider.net.
If it is the part I am thinking:
TIG weld to repair or new/used crankcase halves to replace
Kdxfan4130
Country: Usa
Post by Kdxfan4130 »
Suzuki quad racers had a similar problem. I don’t know what the side cover looks like but possibly a bracket like this maybe an option?
Restore rather than replace
Thirdgenxli just had his laser welded. Looks like new.
Thekid1995
doakley wrote: 09:57 pm Oct 10 2019 Thirdgenxli just had his laser welded. Looks like new.
what is laser weld, never heard of it and where did he get it done? thanks and how much?
Somewhere in NC and it was cheap, $15-20 I think. Send him a PM.
Been thanked: 2 times
I used Bernz-O-Matic aluminum brazing rod to braze my piece back on and it worked like a hot damn. Hit the case part with the soda blaster after and it’s like it was never broken.
