No lighting on my ‘94?
- Country: Usa
Just got a new to me 1994 kdx200 and there is no lighting... a number plate and a normal fender that both look factory and original. Did these bikes come this way sometimes? I wonder if the wiring/lighting coil is present.... maybe someone just put kx plastics on it.
1994 kdx200, 1981 yz465, 1981 xt500, 1975 kx400, 1972 F9 350, 1972 S2 350, 1995 MZ skorpion, 1987 kd80, Baja mini
Re: No lighting on my ‘94?
Yes, they had typical enduro lighting, a tail light and a too weak headlight. Lots of folks strip them off. The front fender on a KDX is a straight swap with every KX fender up to 2019. Look at the wire bundle coming out of the stator cover and follow it up, You should find a yellow wire that leads to a bullet connector. That is your lighting wire. Normally goes to a switch on the right side handlebar and then to the lights/regulator. It can all be added back in fairly painlessly.
- kdx200e_wire.JPG (106.77 KiB) Viewed 1382 times
- Country: Usa
Thanks!
I’ll check it out!
I’d love to have the lights back on.
And the rear fender is zip tie stitched any way.
I’ll check it out!
- Been thanked: 2 times
2003 KDX200: Bone stock
2003 KDX 220:
Boyesen reeds
Gnarly Gold Series pipe
Turbine Core 2 silencer
Fat Bars
Super Sport IMS pegs
Cycra Probend hand guards
Tusk dualsport light kit
LED headlamp
Airbox snorkel removed
Wiesco piston and rings
2003 KDX 220:
Boyesen reeds
Fat Bars
LED headlamp
