Welded front sprocket
Re: Welded front sprocket
Just my $.02 but it would seem prudent to consider an overhaul of the bottom end and all bearings and seals as a minimum. If this is an example of the PO's maintenance you might be better off to get ahead of the game here. Just a thought.
Bearing supporting that shaft at a BARE minimum
- Been thanked: 10 times
That or a sloppy fitting sprocket from the get go or one left on way to long and then becoming sloppy. The counter shaft sprocket will wear just like a clutch basket from being on/off with the throttle only a lot slower.
I would use a die grinder but don’t cut too deep, you can shave it down then give it a hard tap to crack the weld loose but what I’m wondering is maybe it was welded because the spline teeth sheered, this happened to my bike so I welded it a certain way to take it off when I’m ready to replace it.
its normal for you to turn the output shaft and have a little play before the input shaft turns. Not changing sprockets and incorrect chain tensioning over a long period can cause this kind of wear. Someone did not believe in pre/post ride maintenance before you got it lol
- Country: England
Well here is what’s left when I got it off
- 4EC65F05-EB86-4423-92A4-5DA6F28CB714.jpeg (1.62 MiB) Viewed 2260 times
- 4EDFAD62-39F2-4965-B010-0E7026008130.jpeg (1.62 MiB) Viewed 2260 times
- Country: England
What a mess but now
- 0219FABF-738E-4744-94FC-344593AA4B1F.jpeg (1.53 MiB) Viewed 2260 times
- D8FD2A50-7D07-4564-8CDD-CA0D6704D7E2.jpeg (1.45 MiB) Viewed 2260 times
- Country: England
Looking at getting one of the older air cooled kdx now this is finished hoping for £2000 as they are very rare over here
That’s crazy. Good luck in finding an air cooled. I love mine.
