Gear drum
Parney
Country: England
Gear drum
Post by Parney »
Hi just rebuilding the kdx I did not take the gear drum out but are there any marks when assembling to align the selectors all fit in the runners
Re: Gear drum
It only goes together one way.
Parney
Country: England
Re: Gear drum
Post by Parney »
Many thanks all that side done if that’s the case fighting with needle roller at minute tried heat tried bearing puller thing will not move soaking it in penetrating oil for 24 hours
Re: Gear drum
1 or 2 days of a good penetrating oil can make a big difference. Which needle bearing are you trying to pull out?
Re: Gear drum
Post by kdxsully »
Parney wrote: 03:18 pm Jul 25 2019 Many thanks all that side done if that’s the case fighting with needle roller at minute tried heat tried bearing puller thing will not move soaking it in penetrating oil for 24 hours
A lot of people say to just put the case in the oven.
Re: Gear drum
kdxsully wrote: 07:23 pm Jul 25 2019
Agreed. 275 - 300 degrees F. Use gloves & turn the case over on a piece of wood, smack it down to help. Inside bearings may still need the "slide hammer/puller tool" as I call it.
