Welded front sprocket
- Country: England
Some clown has brazed the front sprocket to shaft on my kids 220 only noticed it yesterday any body advice on removing it at home
Re: Welded front sprocket
Air die grinder,
may need a new shaft and sprocket, splitting the cases of course
Sorry to hear it
Sorry to hear it
Yeah, go with that first.
Hold off on the big stuff.
- Molly's 70
Is it brazed or welded?
If brazed, it could be melted off with a torch. Brazing rod melts around 900 to 1000 degrees. Use a wire brush to help remove the brass or bronze, then pull it off & cool it down before it melts the seal.
If welded, I would sand or grind down the weldment as much as possible. Steel melts around 2700-2800 degrees. The fiber cutoff wheels work great as already suggested. A hammer can help compromise what's left sometimes. Depends on penetration. It can be done. Just take your time.
I can tell you what your up against with a picture.
True, if brazed then an oxygen torch might be the ticket. I’d also recommend using that cooling gel stuff near the seal so it doesn’t melt and you have to replace that seal.Molly's 70 wrote: 01:43 pm Jul 15 2019 Is it brazed or welded?
- rungrandpa
- Country: U.S.A.
My son runs a welding business. He said he would pull the shaft out and use an acetylene torch to melt the braze job and that it would come right apart. His opinion is the seal is already ruined by the heat generated by the original braze job.
My nephew welded a shift pedal on a Honda 90 I restored. I took it off with power tools and it wasn't pretty.
- Country: England
As always you kind people are right i took 3 hours to remove it and not a single slot left on shaft arrrrr that’s why it’s welded on ordered new shaft seals etc will up load pictures shortly what was left when I have calmed down
Were they filled in with weld? Did the slots get sheared somehow?Parney wrote: 10:45 pm Jul 15 2019 As always you kind people are right i took 3 hours to remove it and not a single slot left on shaft arrrrr that’s why it’s welded on ordered new shaft seals etc will up load pictures shortly what was left when I have calmed down
If they were filled in, I would guess it’s possible to carefully cut them back out. No way of knowing what’s really going on without pictures. Glad you got the sprocket off, the world of used bikes is unlike anything else.
I don't think anyone is going to pull a shaft through that hole... or recut sprocket slots. New shaft, sprocket, collar, seal and o-rings is the way to go.
- Molly's 70
Agreed.KDXGarage wrote: 02:30 am Jul 16 2019 I don't think anyone is going to pull a shaft through that hole... or recut sprocket slots. New shaft, sprocket, collar, seal and o-rings is the way to go.
Check the chain tension when it is all back together. Sorry that someone did that to the bike.
- Kdxfan4130
- Country: Usa
The heat treating might have changed after all the brazing and reheating if you chose to clean up the splines any ways. One of those amazing backyard fixes that possibly left the seal leaking a lot earlier in its life.
Restore rather than replace
- Country: England
Engine on bench just waiting for my case splitter tool due tomorrow. Not a bad job as long as you look at what people have experienced on this site did the swing arm bearings when engine on bench no need to take swing arm out as just enough room to pull a a threaded bar through and tube
- Molly's 70
Just out of curiosity, are you going to fix only the affected parts, or is this going to be a full on rebuild?
- Country: England
Not a full re build but got all seals and bearings for the side case which I am lifting off and new shift bar.just waiting on case splitter got rubber hammer ready and eaten my frozen pizza so room in freezer for bearings
- Country: England
Where have my spines gone that’s why it was welded when I turn this shaft the input shaft does not turn straight away seems to turn a little bit first is this normal
- 027A250E-09F2-4D29-A8A5-EF35AED6ADD2.jpeg (1.6 MiB) Viewed 4961 times
- A18AB3C6-309E-42EB-BA3D-FEE9026BC7FE.jpeg (1.69 MiB) Viewed 4961 times
- Molly's 70
Ouch! That parts got to go.
- Kdxfan4130
- Country: Usa
Dang. Wonder what the splines look like on the cs sprocket. Heat treating gone awry?
chain tension may have gone awry
I assume one is not going to grab that with a hand and turn all the parts inside.
