Piston
Parney
Country: England
Piston
Post by Parney »
I bought a kdx 220 quiet clean inside my piston has A top I take it this is standard
Has thanked: 66 times
Been thanked: 20 times
Re: Piston
That looks like the stock piston.
Did the previous owner mention head work? Does a stock head look that good??
Parney
Country: England
Re: Piston
Post by Parney »
Totally standard wiseco piston arriving tomorrow bike only done 4000 miles I put motul 5100 in gearbox 10/40 the clutch slipped really bad
Re: Piston
Did you clean the piston top while it was still attached? Sounds risky.
Measuring the piston diameter before ordering another piston would have been a good thing, just in case.
Which 10w-40 did you use?
I am a big fan of putting motorcycle oil in motorcycles. :grin:
pumpguy
Re: Piston
Post by pumpguy »
If gearbox oil has friction modifiers, this may cause clutch slippage. Many on this forum use ordinary Type F ATF with good results.
Parney
Country: England
Re: Piston
Post by Parney »
I put this in it foooooked the clutch
Kdx not like this
Kdx not like this
Re: Piston
That should be fine, it's rated for wet clutch. I would check your clutch spring free length and the disc thicknesses.
Re: Piston
Post by kdxsully »
pumpguy wrote: 09:39 am Jul 01 2019 If gearbox oil has friction modifiers, this may cause clutch slippage. Many on this forum use ordinary Type F ATF with good results.
+1 for atf
Parney
Country: England
Re: Piston
Post by Parney »
You lot over there seem to like ATF oil never used it before but seems to work well on reviews so will try it soak new clutch overnight
Has thanked: 13 times
Been thanked: 21 times
Re: Piston
Parney wrote: 02:10 am Jul 01 2019 I bought a kdx 220 quiet clean inside my piston has A top I take it this is standard
Look, a factory Kawasaki grenade! :shock: :whistle:
Parney wrote: 12:10 pm Jul 01 2019 I put this in it foooooked the clutch
bufftester wrote: 04:38 pm Jul 01 2019 That should be fine, it's rated for wet clutch. I would check your clutch spring free length and the disc thicknesses.
Yep, that should have worked just fine. Like was mentioned, measure everything to see if all is in spec.
kdxsully wrote: 04:58 pm Jul 01 2019
+1 for atf
+2 :supz:
javjacob
Re: Piston
Post by javjacob »
I use the Honda "red bottle" HP transmission oil
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
