So, I couldn’t get the bike started. New plug, has gas, clean carb, has compression. I did start it once with the old plug, and even though my kickstarter was slipping, it started and ran fine. All that’s happened since then is I pulled my flywheel and stator for a once over. Triple checked the timing lines and that I was still on the keyway. Torqued the flywheel bolt to the spec’d 20 ft lbs.
Anyways. My manual says I should have black, white/red, and yellow wires coming from my stator.
I’ve got yellow, white/black, blue/red, and what looks like black/yellow or black/white. I can’t exactly tell the last color, maybe tomorrow I can tell in the daylight.
Yellow wire was unused with electrical tape on the end. Blue/red (edited) was connected to the yellow cable that goes to the light switch. White/black (edited typo) went to white/red in my connector, and black/white (edited)went to black in my connector.
Sorry about the edits. Totally goofed that up.
My question is, is it possible to identify this stator from these wire colors? I’m looking to test the resistance and if these wire colors aren’t consistent with my manual I’m afraid I probably don’t have the right figures.
It’s an 84 motor in an 87 frame. The flywheel has 4 magnets, but I have an 84 flywheel with 3 magnets. Is this an 87 flywheel coupled with an 84 stator? I am confusion.
Thanks for any help. I wanted to get on the trail this weekend!
Im probably gonna record some figures anyways.
