I just started a rebuild of a 92 kdx 200. My current shift shaft is broken just outside of the case. All the usual parts sites say 'no longer available' or just ' not available '. no luck on ebay.. any ideas on where I might find one?
OEM # 13161-1170
Thanks, Rich.
looking for shift shaft
Re: looking for shift shaft
Ebay and hope for a donor motor, or maybe a bike on Craigslist. Beyond that there's not much choice for these older bikes.
Man. I just looked through 900 listings. ZIP! I am surprised. Someone else on here was looking for a fuel tank yesterday. I was surprised there were none on there right now.
That part number was from 1989 - 1994. Good luck.
Maybe someone parting out an engine has one he has not listed yet. Send a message and ask.
- rexemouse
- Country: Southcoast MA
I used an E series shifter in my H engine. So maybe try using 13161-1217.
Yeah, that would probably work now that I look at it closer. The H model piece comes with both parts (the shaft and pawl), they are separate on the E. And you can get an H one for about 40$ new
ahhh.. Great info. I will definitely give it a try.rexemouse wrote: 05:27 am Mar 26 2019 I used an E series shifter in my H engine. So maybe try using 13161-1217.
thanks, rich
I have both shift shafts from an E and an H the one from the H is slightly shorter than the E but extends fully through the case of the E engine and I was able to mount the shift lever. I haven't put the engine in the frame yet so I don't know if it will hit anything being a bit shorter.
Garage:
1989 hybrid kx125 chassis w/ kdx200e engine
1978 gl1000
1984 vt500c
1978 gl1000
1984 vt500c
