Hey guys I have a 84 200 i was looking at the speedo pick up looks like some one took it apart at one time and cleaned it up and it's not working I got continuity in the wires from top connectors to each of the 2 pick up pieces that stick up under the rotor but I'm not sure how it works theres 2 wire pieces that stick up one was bent over touching the side i bent it back down and the other one is in line with the rotor magnet I'm not sure how they go any help would be appreciated
Thanks Mikey
84 kdx200 speedo pickup
vmxmikey451
- 15510621025593328346332466756366.jpg (1.07 MiB) Viewed 3027 times
- Has thanked: 66 times
- Been thanked: 20 times
Re: 84 kdx200 speedo pickup
Have you got the white piece?
Any more pics?
Any more pics?
vmxmikey451
Yea I've got the rotor with the magnet in it
- 15510676835978586197010135797862.jpg (908.32 KiB) Viewed 3022 times
I have never had one of mine apart before.
Do you have the electronic tripmeter / timer unti too?
It looks like all the bottom pieces are there.
vmxmikey451
Yea I've got the timer / trip meter it's in good shape the only way I can get the trip meter to change numbers is to short across the the to leads and it goes to 1 and so on
- 15511251867823453467164509872588.jpg (1.12 MiB) Viewed 3011 times
Is the dark piece inside the white plastic piece supposed to contact the the two wire ends to make a completed circuit??
