Kdx250 governor
Discussion specific to the 1991 - 1994 KDX250 sold in the USA
64tbird
Country: usa
Kdx250 governor
Post by 64tbird »
hey all! :supz: new to the site due to needing help :evil: ! got this basket case 1991 kdx250. got it put together after finding all the missing parts and gaskets and all. never had luck finding the governor lever. everywhere shows unavailable. part number 13168 https://www.kawasakipartshouse.com/oemp ... ine-covers in the attatched pic I believe it goes from the governor down to the stud sticking out from the water pump area but this is the only kdx I have experience with. im a general motors tech. small motors especially oil burners like this or my stihl give me a lotta hell!
kick kick ect and no start not even a hint. desperation sent me to try starting fluid. little at first and tried more than I was comfortable with and still nothing. haven't went thru the carb yet. was hoping I wouldn't have to for a season at least. its getting fuel to the carb- vp pre-mix 40:1. spark to the plug. older plug but didn't look dead. wife verified it was sparking so I don't know what quality of spark but it has something. if it wasn't for not having this governor (power valve?) lever I would look more into spark or already have a carb kit on its way. but will this governor lever issue cause a no start? anyone have a lever and maby that lower cover they wanna sell? as far as I can see that's all that I need to go have some fun!
kdx250 gov 2mp size.jpg (185.67 KiB) Viewed 152816 times
Has thanked: 162 times
Been thanked: 40 times
Re: Kdx250 governor
Welcome to kdxrider.net.
13168 is only a reference number. The part number is 13168-1442.
It is not related to a start / no-start situation.
64tbird
Country: usa
Re: Kdx250 governor
Post by 64tbird »
That makes sense! I tried that number as well and no luck so will verify good spark and probably pull the carb out! Any threads or tips for carb mods or replacement/upgrade carb? I'm in Colorado so 6200 ft and will ride between that and 9k so don't have much air! Guy I got it from rejetted it back when he had it running and said it ran great but would rather spend the money now to do it for good
Re: Kdx250 governor
Is everything else in proper order? Exact jetting seems like something to be worked on after it is running fairly well.
64tbird
Country: usa
Re: Kdx250 governor
Post by 64tbird »
Kinda my thought. The bike sat in a shed for a few years with the carb wrapped up in a plastic bag. It looked ok but just a bit of ethanol could gum it up pretty bad. The first few kicks I believe the governor was pulled out all the way so would have had the valves set for high rpm I believe. Pushed it in and still nothing. I believe all else is good. Governor, electronics and carb are the only things I haven't been thru. I will look more into spark first and report back! Do these have an on/off kill switch? All I can find is a momentary push button near the clutch handle.
Re: Kdx250 governor
Push in the button until it dies.
Re: Kdx250 governor
Basket case bike, what are the compression and leakdown numbers? It needs to be mechanically sound, with intake free of air leaks (cracks in boots, reeds good, etc). Clean the carb...twice...to start. If it won't fire off on starting fluid I'd be looking at compression first. Have you pulled the flywheel cover and checked the coils?
Dan 250sr
Country: Japanese version
Re: Kdx250 governor
Post by Dan 250sr »
1988 kx 250 use same arm
Dan 250sr
Re: Kdx250 governor
Post by Dan 250sr »
64tbird wrote: 06:27 pm Feb 24 2019 hey all! :supz: new to the site due to needing help :evil: ! got this basket case 1991 kdx250. got it put together after finding all the missing parts and gaskets and all. never had luck finding the governor lever. everywhere shows unavailable. part number 13168 https://www.kawasakipartshouse.com/oemp ... ine-covers in the attatched pic I believe it goes from the governor down to the stud sticking out from the water pump area but this is the only kdx I have experience with. im a general motors tech. small motors especially oil burners like this or my stihl give me a lotta hell!
kick kick ect and no start not even a hint. desperation sent me to try starting fluid. little at first and tried more than I was comfortable with and still nothing. haven't went thru the carb yet. was hoping I wouldn't have to for a season at least. its getting fuel to the carb- vp pre-mix 40:1. spark to the plug. older plug but didn't look dead. wife verified it was sparking so I don't know what quality of spark but it has something. if it wasn't for not having this governor (power valve?) lever I would look more into spark or already have a carb kit on its way. but will this governor lever issue cause a no start? anyone have a lever and maby that lower cover they wanna sell? as far as I can see that's all that I need to go have some fun!kdx250 gov 2mp size.jpg
1988 kx 250 has same governor arm
Dan 250sr
Re: Kdx250 governor
Post by Dan 250sr »
64tbird wrote: 10:57 pm Feb 24 2019 That makes sense! I tried that number as well and no luck so will verify good spark and probably pull the carb out! Any threads or tips for carb mods or replacement/upgrade carb? I'm in Colorado so 6200 ft and will ride between that and 9k so don't have much air! Guy I got it from rejetted it back when he had it running and said it ran great but would rather spend the money now to do it for good
I've got kx 500 inlet manifold, same as some kx 250s, and 38 carb
64tbird
Country: usa
Re: Kdx250 governor
Post by 64tbird »
Dan 250sr do you have a governor arm?!? If so name your price!
Dan 250sr
Re: Kdx250 governor
Post by Dan 250sr »
Hello no sorry, there are some on ebay. Just be careful as some are wielded onto shaft. If you take casing of your be able to make wielded one work..
Dan 250sr
Re: Kdx250 governor
Post by Dan 250sr »
There's one bolt on arm on ebay for kx 1988. Then later one's seem to be wielded straight onto shaft. So your have to split clutch case to fit . Or grind wielding off and re drill hole .. your notice shaft is tapperd where arm mounts on, and arm mount hole is tapperd to .
Dan 250sr
Re: Kdx250 governor
Post by Dan 250sr »
1988 .1991 kx 250 cover is the same and rubber boot is same
Re: Kdx250 governor
From Partzilla:
This Kawasaki 13168-1442 LEVER,GOVERNOR Not Available fits the following models and components:
Kawasaki Motorcycle 1990 KX250 - KX250-H1 Engine Cover
Kawasaki Motorcycle 1991 KX250 - KX250-H2 Engine Cover
Kawasaki Motorcycle 1991 KDX250 - KDX250-D1 Engine Covers
Kawasaki Motorcycle 1992 KDX250 - KDX250-D2 Engine Covers
Kawasaki Motorcycle 1993 KDX250 - KDX250-D3 Engine Covers
Kawasaki Motorcycle 1994 KDX250 - KDX250-D4 Engine Covers
Dan 250sr
Re: Kdx250 governor
Post by Dan 250sr »
:prayer:
I just look at pictures and compair lol,
