Idles higher when bike is upright?
TheHabitRabbit
Post by TheHabitRabbit »
So my 1994 kdx runs great, except one odd thing is happening at idle. When i have it leaned over on the kickstand the idle decreases almost to a stumble, then when you stand it upright the idle increases. I noticed a very small amount of gas seems to be coming out around the fuel adjustment screw. I just got a rebuild kit, but i was wondering if anyone knew what would make it change the idle just from leaning over like that. I've never heard of this problem and I haven't found any similiar situations online. Any insight is much appreciated!
Re: Idles higher when bike is upright?
float level?
kdxdazz
Country: thailand
Been thanked: 4 times
Post by kdxdazz »
Yep as already it's the float level. When I connected up my wideband 02 sensor to another bike the AFR changes while going around corners. Check your float level using the clear tube method as this will give a guaranteed accurate result where as just setting the float height is dependent on the condition/twist in the float
TheHabitRabbit
whats the clear tube method?
RoboMonkey
Post by RoboMonkey »
Like this...
Tyl3r
Post by Tyl3r »
How do you guys connect a hose to the bottom of the bowl? Make a custom fitting or something? I always just did the blow into some fuel line and slowly raise the bowl by hand to see where it closes at. I can't remember off hand where the correct position is (maybe level with the flange for the bowl?), but I got the info to do this from a thread on this forum somewhere. I'm sure the method described above will work better, but if you don't know how to connect the hose (like me), that's another option.
kdxdazz
Country: thailand
Post by kdxdazz »
I just used a rubber grommet with a hole in it. Had to take the main jet out.
B737driver
Post by B737driver »
It could be your throttle cable binding and opening the throttle a bit when it’s leaned over. Turn the handlebars when it’s on the stand to check.
Live to Fly
Fly to Live
