Wanted to see if anyone else was running a 14, and if so, what did you do make it work? I figure a custom case saver would do it... but the time and cost of that would probably be about the same as ordering a 44T for the rear (has a stock 47 on it now), and have nearly the same gear ratio.
Hmmm... thinking about this though, I think I have a piece of 3/8" aluminum at home. I could clamp the stock case saver to that, drill the holes in the right spot. Then make a cardboard template, and cut one out
