hey for you have done this, how long will it take to change the piston and clean everything in there you know kips. just wonderin if it is doable in a day or a weekend . thanks a bunch guys.
About 3 hours from start to finish if you know what your doing.... a little longer if you don't.
*** Administrator //*** ****'95 KDX 200/****
On the KDX, I usually do the tear-down on evening 1, the cleaning and fitting and KIPS reassembly on evening 2, then put the jug on the bike and reassemble on evening 3. Usually all 1 to 1.5 hour sessions. The KX is faster (carb stays on case, don't need to pull head to do power valves, etc), and last time I did it all in 1 evening. The worst part for me is the coolant. No matter how I do it, it always ends up spilling some or draining out of some crevice or something. Ick.
it just depends on how bad your powervalves are. if they have never been cleaned before that will take you awhile. just doing the rings shouldnt take you over 3 hours.
not bad time, but it does sound like i am going to be spending some time on the bike and by cleaning everything up and after break in i should have a much cleaner running bike and have a moderate increase in power than what i am used to just from cleaning and changing the piston. more power=one happy dirt biker.
the trail rider wrote:i should have a much cleaner running bike and have a moderate increase in power than what i am used to just from cleaning and changing the piston. more power=one happy dirt biker.
On the KDX, I really don't take it apart to change the piston/rings- I take it apart to clean the KIPS and while it's apart, since it's apart and everything, I pop a new piston in.
The KX125 is totally the opposite! I take it apart to put new rings and/or piston and while it's apart, since the thing's staring me in face, I clean the KIPS.
well this piston change is mandatory, in my mind i cant see myself paying 1,000 bucks to fix my motor to say to myself i could have spent 175.00 and not even change it again until it needed be, and not worrying about my motor blowing up every second. at 15 i cant afford a thousand dollar repair bill and that money can be saved in buying my dads 78 lifted gmc jimmy. just seems more logical to me. thanks guys for all your help on this subject.
